Online: HD17, speedzter
Eastern Big Twin, SEST tuning ?
    Do Eastern big Twin work with SE tuners, eg SEST ?
    If not, any other recommendations for Good Dyno tuners that are experienced with the  SEST around Melbourne or Geelong ?
  • Harvey
    Harvey
    No Brian is big on the powercomander.
    But there is another bloke in the scoresby area thats very good with the serts but alzimers is at work.
    Will try to find out later.
    So appears EBT is out, no other recommendations ?
    Glad my bike is carby and I have access to a wideband O2 meter !
  • EBT
    EBT
    Hi Guys,
    Just to update this post. We certainly do Dyno tune Se pro tuners. It's been a long time since we fitted a Power Commander to a Harley. Basicaly there is no room for them on the new Harleys and insufficent adjustment. The SE Pro Tuner is an excellent tuning tool. About 70% of my tuning is with that unit. The unfortunate and sad part of the process is that over half of those bikes have already been to another Dyno shop. I can read all maps loaded into these bikes and not one single bike has had a custom map done. Regardless of what the owner has been told or paid for. NOT ONE!!!  We carry out full twin cylinder advance mapping covering every adjustment the tuner allows us. The download or canned maps that are used by other  shops are so far out we dont even use them as a starting point. The SE Pro Tuner is a great tool along with dedicated time and effort we acheive awesome results in rideability, fuel economy and performance,
    Cheers Brian.
    Only about 3 years late, but good to know !
  • Deadwood
    Deadwood
    Lol
  • Rob_hendo
    Rob_hendo
    been looking at getting my 07 tuned aswell, running a SE tuner but I think ill big bore it and put Cams in first! interested to find whos the man to see though cause im around Bayswater area
  • Deadwood
    Deadwood
    Doc Hogs
  • 78gold
    78gold
    Having my bike done by EBT next week,
    585 Easy Start Cams
    Adj Pushrods
    Lifters
    Gear Drive kit
    Full Dyno Tune
    Also getting a Supertrapp 2 into 1 fitted (Bought off a mate but not fitted yet).
    Cant wait to open her up after work done.
    Will post my results when complete.
    Ride Safe
    Nigel
  • robots
    robots
    Hi,
    Sounds good 78gold, you have nice ride to sydney?
    Thanks
    Robots
  • 78gold
    78gold
    Pauly,
    Long story I will post on here one day.
    Started life as an 06 Lowie with the 6 Speed 88"
    Then bought a 103" off a classified on here and had HD Dandy install.
    They put a "canned" program in and even though I asked for a slightly "rich" tune it was very lean and I mean very lean.
    You should see the header pipe.
    I had EBT put the cams and pipes on and then tune properly, the difference is unbelievable.
    The power and torque figures for the before were taken from a Dyno reading done on a 2013 103" sock motor, although not mine.
    I simply used them for a base point to see what I could get over and above stock HP.
    The ride home was fun but F^%$#& hot, at one servo the guy told me it was 45 Degrees outside. I stopped about 6 times for fuel and/or to hydrate myself, must have drunk about 8 litres of water, 2 Red Bulls and 2 Gatorades.
    My brother was following me towing my trailer so didn't open it up too much but a couple of times I did there was plenty there.
    Ride Safe
    Nigel
    Sounds as though you have a new lease on life with the new tune, enjoy!
