Online: B0nes
Another thundermax Question
  • Brett
    Brett
    Hi all. I have a t-max with the base map loaded for an aircleaner kit and S/E slip on's for my dyna fatbob ,trouble is I am about to fit Vand H big shot staggereds,Question is ,do you think I will need to download another map or will this one be close enough for the auto-tune to do it's stuff?Cheers
  • GREG
    GREG
    Auto tune will look after it.
    Just remember that it has a function that allows how fast it will learn and by what percentage changes will be made each start up cycle. It will only learn (adjust to the new conditions) up to the amount that it has been set for, so more frequent trips which get up to normal operating temp, with shut down and cool down will help.
    But it is way too easy just to look for a map which closer matches what you have fitted. Should only take you 20 min to find the map, hook the puter up to the bike and "LINK" away......new map ready to go.
  • Brett
    Brett
    Thanks fellas,Will go with the map that was downloaded for me and see how she runs before I venture to far.There don't seem that there is many base maps to choose from for Dyna's,I could only find around three that suit a stock 96cube with A/C kit and pipes,Maybe I just didn't look hard enough.cheers
