Online: beaglebasher
Rear struts wanted
  • Ironman
    Ironman
    Hi there,
    does anyone know where i can buy rear solid struts
    in Oz for sportys? Love the slammed look, but have now put
    a burn mark on my gaurd. Stupid I know.
  • BONES666
    BONES666
    I've just had a set landed from the US. You'll find them on Ebay :)
  • Ironman
    Ironman
    Its got a lowering kit on it, still with shocks on it. Just really low.
    The tyre rubbed inside the gaurd whilst doing high speeds, causing it to heat up.
    In regards to ebay, I cant seem to locate them on there.
    Is it Straight or Curved ones?
  • Ironman
    Ironman
    What in regards too?
    I just relised the you are talking about replacing the Shocks with Struts, I thought you where looking for Rear Guard Struts.
    anyhow I do know I guy that may have a pair if 11"one's I will find out tomorrow for you
  • Nightrider
    Nightrider
    Licks in the states also have em.
    Ive seen pics of some guys that have cut off the fender struts and floated the fender low down over the tire looks sick.
    wouldnt be hard to do you would just need to find a new place for the indicators.
    Give us a call if you got some time be nice to catch up.
    NR
  • r0880
    r0880
     Considered a weld on hardtail conversion?
  • BONES666
    BONES666
    Here you go
    http://cgi.ebay.com/ebaymotors/Sportster-Struts-Rigid-Hardtail-Lowering-Kit-SLAM-_W0QQcmdZViewItemQQhashZitem5d2b6d7647QQitemZ400160552519QQptZMotorcyclesQ5fPartsQ5fAccessories
  • Ironman
    Ironman
    Cheers guys.
    Yeah wanted to get some quick. Aussie dollar is really good
    atm so get some from US.
    Thanks
    NR, yeah mate should find some time. Found another Iron rider too.
  • Nightrider
    Nightrider
    PM me ur number again mate phone got wiped out and lost heaps of numbers.
  • Harley_Dude
    Harley_Dude
    hi mate I have a set in sydney that you can have if you like... I dont post out of lazyess though...
    I tried the bolt on struts but dont like the end product. I think I am going to try and go a hard tail frame now, or just give up.
    Anyone with any adivce on making a 2011 48 into a hardtail would also be appreciated.
