Front End Change
  • SirKGuido
    SirKGuido
    I'm looking to change my 2005 Super Glide front end (forks, trees and wheel) to a Wide Glide front end.
    1. Does anyone have 2nd hand parts and are looking to sell?
    2. Also looking for all tips and hurdles fron anyone that has done the same work. And where you got your parts?
  • carl
    carl
    Ive been doing some checking out myself, got a 2005 super glide as well. You can get  10  in wide triple tree,s with 41mm forks ,fully chromed, with or with out rake from the states ,landed here in Oz for around 700 bucks  . Worth thinking about !
  • SirKGuido
    SirKGuido
    word has it that depending on how much rake you put in at the trees if any can really effect the handeling of the veh at arounf 100 to 120 kms and that your bearings will take a bashing.. so just watch out.. the more i look in to it the more there needs to be done.
  • carl
    carl
    Yea true , The difference between a dyna glide rake and a dyna lowrider rake is 4 deg. the ones i,m looking at have a 3 deg rake, so should be ok. I doubt the bearings would have a problem with that
  • black29d
    black29d
    I converted my 07 superglide 2 years ago, but my trees are made from solid billet 40mm aluminium from a company up on the gold coast
    There were done in stock rake, but they make them in any 3 and 6 degree rake, and also with hidden top if you want.
    I fitted a stcok softail wheel and I find the handling ok with stock rake, it gives a little more ground clearnce with the forwards
    hHere is the link to my original posting
    www.hdforums.com.au/Default.aspx
    and here is the link to the supplier
    www.a1cycle.com.au/
  • SirKGuido
    SirKGuido
    cheers im lookin now...
