Online: Stuart
Kms??
  • SirKGuido
    SirKGuido
    Lookin at getting another Dyna but the Wide Glide im looking at has 59000kms on the clock. Is that too much for a 2006 model?
  • Cubicinches
    Cubicinches
    My 2006 Street Bob has 85,000 klm on it. 60,000 klm is nothing. Anyway I guess you'll be looking at putting a 95 ci kit in it. If it's a six speed make sure that it got the upgrade selector kit put in. Easy to tell, if the neutral light stays on or flickers it needs the selector refit.
    The stock rotor sheers the bolts so replace that with the after market welded rotor housing. Do all this when you put the 95 ci kit in it.
  • SirKGuido
    SirKGuido
    thanks for the heads up im goin to take a look at her soon!
  • SirKGuido
    SirKGuido
    one would hope so i still have my 05 with only 12700 on it :) but two bikes are better than one!
    hey Taffy and SirKguido, both you guys need to get a life..... before I headed up here I did 45,000 in 22 months on my 07 Street Bob
  • wilso
    wilso
    depends on asking price - i waited till i found low kms for the right price - my 99 had 9000kms on it when i bought it in 2008 - and it was a great price - patience is the key
  • SirKGuido
    SirKGuido
    i played gridiron for qld and i got a helmet through my leg spiral fractue and compartment syndrome was lucky to keep the leg.. but back riding now. just a bit hard to change gears now as my left foot doesnt move or face forward. its a full leg movement now ha
  • SirKGuido
    SirKGuido
    cheers mate :)
  • ==ShaDoW==
    ==ShaDoW==
    was wondering if anyone else had picked up on the 96B comment well done sir.
  • Dynamic
    Dynamic
    I recall some concerns about the 2006 Dynas from the US forum. There is something about the primary to gearbox mounting that makes this year unique. One less bolt, I think it was. This causes the inner primary bearing to fail. Or perhaps it was the quality of the bearing. Anyway, the kerfuffle caused me to stay away from 06 Dynas.
    Worth doing some research, expecially if you're about to load up the engine.
