rear axle hex head and nut size 2010/2011 fxdc
Daggs
yep yr spot on with the sizes there grumpy,
I made my own spreadsheet with all major fornt end, rear end and engine/service bolts with torque settings and head, torx sizes. I know its all in the manual but I wanted a separate sheet with what i think are all the most common ones.
Have it laminated and hanging on my garage wall
Daggs
you dont need much in the way of metric but handy to have, some of the brake caliper stuff, 12point 10mm, axles, bottom fork cap bolts, only bits and pieces...
