Online: John.R
Wax marks
  • FLSTC
    FLSTC
    why use an angle grinder when a guerney does the same thing more efficiently
    Once apon a time in a past life, Please dont bag me out for this,,, I was a Car Detailer, Yes I admitted it ,, A Car Detailer. ,,,White Sprit's on a rag  and a angle grinder
  • clarkie
    clarkie
    try using automotive prepsol,good wet rag rub hard and clean off with dry rag,if on wrinkle finish use a soft tooth brush to get polish out dip brush into prepsol and srub.try it it works.
  • Bungee
    Bungee
    WTF?
  • the_mongrel
    the_mongrel
     Dude... OK... If you are going to wax your legs... well that's your business... But don't do it near the Harley!!!
  • poverty rider
    poverty rider
    try spraying windex onto a soft rag then rub the affected area.
  • ductor
    ductor
    didn't that wd40 email have something about that?
  • ductor
    ductor
    I've got a new can on my desk and it has a flammable gas warning onthe back
  • safadao
    safadao
    I'd love to try that, but I'm sure I'd end up with a valve to the scrotum
