Online: John.R
Where to Get Mobil1 V-Twin In Adelaide?
  • Purnong
    Purnong
    As per the title
    Does anyone know where to get Mobil1 V-Twin in Adelaide?
  • kingchops
    kingchops
    I think Dazza is on the money. I've asked around at a few local shops in Adelaide not many shops stock it. Hyperformance Cycles on Main North Road have it.
  • Purnong
    Purnong
    Ok, Thanks guys will check out the mobil distributors and let you know what I find
    On the subject, What grade of oil are you all running in your gearboxes?
  • Purnong
    Purnong
    Ok, Found the oil at the distributor
    For anyone looking for this stuff I got it at
    Roto oil
    6-10 Streiff Rd Wingfield SA
    PH 8359 8995
    Very helpful people and even spoke to the oil tech in Vic about gearbox oils while I was there
    Price was $107.47 for a six pack or $17.90 per 1 QT bottle, Doesnt matter if you buy the six pack or single bottles the price is the same
  • ANDYK
    ANDYK
    Purnong i just go to our local autopro and they order it in same price
  • pat
    pat
    fyi
    https://www.mobiloil.com/USA-English/MotorOil/Car_Care/AskMobil/Mobil_1_15W-50_in_Harley-Davidsons.aspx
    its cheaper but not fricton modified so not in the clutch comes 5l. v twin is for v twins and some have 1 fill hole(so it goes to clutch)
    15/50 not as common standard is 5/50
