some mods to the iron
  • Brucey
    Brucey
      lets see if this dam thing works
    Sorry guys i cannot get this photo bucket thing to link and display Bruce
  • Damon
    Damon
    Take the 'Direct link' text associated with any picture and paste it in mate.
  • terroristone
    terroristone
    here you go mate
  • Brucey
    Brucey
    Thanks for that terroristone i dont know how you did it but you did it
    Thanks also for the help Damon i will have to have a go on the test forum
    Damm this new computer
    well as you can now see the indicator mounts where giving me the irrates they never pointed the same way so they had to go.
    So into the garage with some lumps of 316 stainless and they where done also when i flipped the mirrors the nylock nut look does not appeal so a knocked up some cap nuts at the same time
    ps it helps if you have a lathe and mill
    Give a buzz with the polishing mops and jobs done.
    Cost big fat zip hours wise about 5
    Bruce
