Online: HD17, baldy1450
Putting in lowering kit.
  • ductor
    ductor
    You need a press to get the old bolt out of the shockies. You don't need to take the rear wheel off . I used a jack and removed and altered 1 shockie at a time.
  • ductor
    ductor
    I haven't seen the video but to remove the existing bolts you need to compress the shockies to take the preasure off the circlips holding the plate that the bolts are fitted to .They have a locking nut on the inside. It's a few years since I've done mine but the above is basicly correct.
  • Sparra
    Sparra
    On my bike,a 1995 FXSTC I had to remove the shocks and take the whole shock bolt out and install new adjustable ones and this process required the use of a press...Looking at the video it's a different setup to mine.
  • ductor
    ductor
    Sorry mate mine's an '08 twincam 96
