Online: B0nes, John.R
Chrome Polish & Cleaner Recommendaiton
  • vladt
    vladt
    Howdy All,
    Any recommendations on which brand/type of Chrome polish/cleaner is the best out there? What works and what doesn't!!!
    Please let'us know.
    Vlad
  • PigironBob
    PigironBob
    I use Autosol at the moment, seems to be ok.  Had it left over from my cousins street rod, when he gort rid of it I grabed the Autosol and Maguires polish.
  • rkc07
    rkc07
    I use the maguires chrome polish ..comes up a treat and from my close inspections it doesnt seem to leave visible scratch marks ..bit suss about using it for the first time but after doing a test patch I was happy
  • Purnong
    Purnong
    I use a can of cheap window cleaner on the chrome only
    Works well, easy to use and cheap
  • Soapbox2627
    Soapbox2627
    I only use Mister Sheen
  • Purnong
    Purnong
    Mr Sheen is good too
    Even has a pic of Wozza on the can
    Must be good
  • Tapey
    Tapey
    I go with DLUX66. The best I have found so far, before that it was Mr Sheen.
