Somewhere to hide your trickle charger connector (Heritage, etc)
  • Duanneb
    Duanneb
    Just a thought on where to hide the trickle charger connector once you've hard wired it to you bike.  I noticed there was a hole on the underside of my tank console's leather pouch, which I only use to stash a small cable lock for my helmet, so figured it would hide away nicely in there...
    Just put the wires through the underside and underneath the tank to the battery.
    Wires tuck out of the way of the seat mount.
    Plug into charger when required.
    Out of sight when not required.  Well, it works for me.
  • AJ56
    AJ56
    Mine hangs down behind the right hand side of the oil tank. Can't be seen when not in use.
  • SoftailSteve
    SoftailSteve
     mine is left side near oil tank frasers at newcastle fitted mine do not recall how much, nice job
