NEED MAP TO SUIT 1200 SPORTY
  • nimo07sporty
    nimo07sporty
      HI LADS I JUST ORDERED  A TTS FROM M&M AND A SCREAMING EAGLE HEAVY BREATHER WILL BE PUTTING THEM ON ONCE THEY ARRIVE HOPEFULLY NEXT WEEK.
     MY QUESTION IS THERE A BASE MAP TO SUIT S&S SLIPONS, AND THE HEAVY BREATHER BIKE IS STOCK OTHER THAN THOSE MODS.
  • beerman
    beerman
    HANGIN NIMO, GOT A FUEL PAK FOR MY '1O SPORTY, WITH THAT CAME A WHOLE ARRAY OF DIFFERENT MAPS, RANGIN FROM YEAR OF BIKE, TYPE OF PIPES, TYPE OF BREATHER. THUMB DOWN THRU THEM TIL YOU ALIGN ONE TO YOUR SETUP. IT COULD ALSO WANT TO KNOW PART NUMBER OF PIPES  HOPEFULLY YOURS WILL BE SIMILAR     GOOD LUCK
  • nimo07sporty
    nimo07sporty
    thanks for the input fellas hopefully tuner will be here in the next week or two fingers crossed will let you all know how i go once i get it and play around with it
