Online: WideglidingNZ
S&S E SERIES JET DIRECTION
  • JDKSPLACE
    JDKSPLACE
    I HAVE AN "E SERIES " S&S  CARBIE..CAN ANYBODY TELL ME... ,IS THE INTERMEDIATE JET(THE ONE  AT THE BACK,CLOSEST TO THE THROAT)ADJUSTABLE?AT THE MOMENT EACH TIME I TWIST THE THROTTLE IT SHOOTS PETROL OUT TOWARDS THE AIRFILTER. IS THIS NORMAL,WHAT DIRECTION SHOULD IT BE SHOOTING?..ANY INFO REALLY APPRECIATED,CHEERS JAY
  • JDKSPLACE
    JDKSPLACE
    THANX HEAPS JUST PULLED IT OFF MY BIKE,AND WAS ABOUT TO STRIP IT DOWN.THANX AGAIN!!!!
  • DynaRider
    DynaRider
    No point in having an accelerator pump, and then turning it off.
    Look for a superior solution.
    Are you saying it is squirting out while the engine is NOT running?
  • angry
    angry
    sounds like your accelerator pump nozzle or jet is facing the wrong way,very carefully turn it to face toward the centre of the inlet manifold[down the carb throat]. S and S have a pretty comprehensive set up and tuning book usually supplied with the carb.
  • JDKSPLACE
    JDKSPLACE
    IVE GOT IT ALL SORTED NOW,THANX 4 THE REPLYS,RUNNIN SPOT ON.CHEERS
