03 Sportster - cant start
  • JerryD
    JerryD
    Hi all, got myself 03 sportster 883, was going all fine for last 2 months. Didnt start it for 4 weeks or so, it is on trick charger.
    Today, trying to start, engine turns fine & strong, but cant start.
    Waited for an hour, same thing.
    Any ideas, pls?
    Thanks / jerry
  • JerryD
    JerryD
    fuel ok, its on, sparks Ok...
    still, sounds as full dont get in.
  • JerryD
    JerryD
    thanks quickdave & all
    will get into it over weekend.
    this is such great forum, thanks guys.
  • JerryD
    JerryD
    SORRY...kiwidave....
  • Aunty X
    Aunty X
    Perhaps you may need to get a new battery. If you have the original battery in it, you've got a good life out of it. I'm just guessing.
  • Tmode
    Tmode
    If you have a good battery, spark and fuel, the only other thing the engine needs to fire up is air.  Is the air filter clean?
    Also, if the fuel has been sitting in the bike for a few of months it may have gone off.  (yes it does happen).   Fill it with fresh petrol and try that.
    Tmode.
  • grim
    grim
    Hey Hey JerryD----I know its easy to do---check the kill switch is on--Ive done it b4, fn embarrasing when ya mates are there
  • als1200
    als1200
    g'day mate, how did you get on Jerryd.
    i have a Quad for my daughter and i found if i used Vmax fuel it would not start. ditch the good stuff (so i thought) and put in normal unleaded and it was fine. Bike shop told me that one.
  • kensim
    kensim
    choke full on
