Online: obisteve
Risers on Fat Boy, and tacho wiring (or new bars?).
  • Taffymarsden
    Taffymarsden
    The bars on my Fatty are fairly low. They are pretty good but it feels like it would be more comfortable if they were a bit higher. I reckon the tacho wiring won't be long enough though so maybe different bars would be better than risers. Any comments on this, or what is a good comfortable general purpose bar? (Note the dainty way I'm holding the camera - practising for when I have tea with the Queen).
     Thanks fellas.
    17Jul10033.jpg picture by taffymarsden
  • Daggs
    Daggs
    sorry don't know about the cable length but I do reckon that some 4" or 6" risers, pull backs if neccessary would make it look better and probably more comfy from what You have said
  • the_mongrel
    the_mongrel
    Hi mate,
    I put 4 inch pull backs on my fatty and they fit without an issue - no need to extend wiring etc.
    Question though... Did your 05 come with a hydraulic clutch, or is that a mod? my 2010 has cable!!
  • Sparra
    Sparra
    Standard Fatboy bars may be a little higher and come back further....
  • the_mongrel
    the_mongrel
    Ahh... makes sense!
    Oh yeah... nice colour too. :)
  • the_mongrel
    the_mongrel
    Robo - Wouldn't 6 inch need new cables etc??
  • the_mongrel
    the_mongrel
    Unless his bars come back in to 1 Inch at the risers??
  • the_mongrel
    the_mongrel
    SERIOUS!! My front brake line does not have much left in it. I doubt I could go any higher. Maybe to 2010 models they got skimpy.
  • the_mongrel
    the_mongrel
    Thanks Taffy.
    That is one thing I wanted more than anything was the Radius. I would have eaten baked beans for a month if I had too. :)
    I love the look and the sound - they are worth every penny!! :)
  • the_mongrel
    the_mongrel
    Ok - He will need the ones that I got. They are for 1.1/4 bars. They have been out on backorder for ages - but I managed to find a set somehow. They work well too. I think they are the only risers that HD make to fit 1.1/4 inch bars. They make a 4 and 6 inch versions I think.
  • Beef
    Beef
    I have a set of 4" pullback risers if you are interested. They are LA Choppers, not genuine HD. PM if you are interested.
  • the_mongrel
    the_mongrel
    Sorry - Don't mean to rub it in!   :)
  • the_mongrel
    the_mongrel
     Taffy - Make sure the risers you get are to fit 1.1/4 bars.  I nearly bought risers as they stated they were 1.1/4 inch.  Good I thought!! NOOOO!!  That was just how think they were and were only for a 1 inch clamp size.
