Online: WideglidingNZ
burnt plastic on black pipes
  • aussie_harley_girl
    aussie_harley_girl
    Anyone got any suggestions on how to get burnt plastic off my black pipes...its only small about the size of a 1cent piece but its annoying the crap out of me......the pipes and my wet weather gear didnt get on lol....ive tried the harley black denim cleaner it didnt work...to scared to try anything else
    Start the Bike up , make the Pipes Hot and Wipe off with a Wet Rag
  • BURTO
    BURTO
     If that dont work, you can try acetone.............(just check somewhere inconspicuous it don't take the paint off- shouldn't tho as the paint should have been baked on)
  • Daggs
    Daggs
    citric acid may do it
  • the_mongrel
    the_mongrel
    +1 on heating the pipes!
  • evoshovel
    evoshovel
    I got rubber from my boot melted onto my pipe and try clean it with one of those sponge on one side and green scour pad on the other and scratched my pipes. So I wouldnt try that.
    aussie_harley_girl
     thanks for the heads up evoshovel......think ill stick to heating the pipes up and see how that goes...thanks guys
  • V2Evo96
    V2Evo96
    I have used oven cleaner successfully on CHROME pipes but have never used it on coated black pipes.
    I would try what Walka said first-- heat em up and wet rag wipe off -- suggest oven cleaner as a last resort.
    Toothpaste is also good for very light scratch removal on helmet visors.
  • fathog
    fathog
    it should burn off
