Online: John.R
Won't Start in Gear
  • Fangio
    Fangio
    Now i'm off the green stuff for a while and the booze is undertaken in moderation....need to get that in from the start
    but ever since i had my accident, the street bob will not start in gear.
    netural is fine.
    when in gear it goes through all its start process then hit the action button and nothing.
    a bit of a pain in the arse but nothing major....strange...
    ok let the crap fly...
  • ductor
    ductor
    The clutch  switch may be damaged. Does the engine light stay on when running? Like the brake light switch.
  • ductor
    ductor
    The starter might need new brushes. Is it struggling to start in neutral? Your battery may be on the way out too.
  • Fangio
    Fangio
    in netural kicks over fine, battery sounds strong.
    like i said not a real hassel, just werid.
    thanks for info mate
  • cm364352
    cm364352
    +1 on faulty cutch kill swich or associated wireing.
  • AJ56
    AJ56
    It will be either the clutch switch. or the lever is not engaging the switch.
  • WozzA
    WozzA
     Clutch switch ????   WTF ???   when did they put those in  ????
  • monarofan
    monarofan
    +1 on the clutch safety switch
