Big Radius V&H buy?
  • melb-ourne
    melb-ourne
    hi Guys
    I am going to order the Big Radius and want run it thru you guys to see if its ok for a 2011 Forty Eight.
    I live in a quite area and don't want to piss my neigbour-off and especially EPA in Melbourne.
    "Big Radius Black is equipped with one-piece full-length heat shields coated in durable high temperature matte black ceramic and tuned louvered core baffles pre-installed".
    http://www.vanceandhines.com/products/sportster-0410-bigrad22blk/bigradius22-blk.html
    I assume tuned louvered core baffles will make it queiter?
  • melb-ourne
    melb-ourne
     Thanx alot for your help guys
    We did Pipes there a few weeks ago
    http://www.hdforums.com.au/Default.aspx?tabid=71&forumid=1&postid=233483&view=topic
  • melb-ourne
    melb-ourne
    http://www.hdforums.com.au/Default.aspx?tabid=71&forumid=15&postid=241235&view=topic
    I am getting from MM Cycle.
    may be ebay.?
    http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=260631533430&viewitem=&sspagename=STRK:MEWAX:IT#ht_3071wt_1074
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=230501645437&ssPageName=STRK:MEWAX:IT#ht_1564wt_1102
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=350376030797&ssPageName=STRK:MEWAX:IT#ht_1495wt_1102
    OR Harley Dealship
    Forget M & M give me a call and a Chance,,, VPW 03 8405 9212, I  always offer very good discounts to forum members
  • Taffymarsden
    Taffymarsden
     Bought an 05 fat boy with Big Radius. Lasted 4 days and told the dealer to put the SE2 pipes back on because the V&H were so loud I was sure I'd get booked. The SE2s turned out to be louder (and deeper) and now I'm wearing ear plugs (ok, turns out the original owner removed the baffles). If I still had the V&H I'd put them back because they look so good. The sound is loud but a bit sharp...more of a crack than a thud if that makes sense. Short pipes are always less deep. They look great though, esp on a soft tail since it shows the "hard tail" rear suspension so well. Some people think they are a bit common now but I'd still take them back.
