Check this site out! Club for Serving Military, Ex Military and Military Supporting Personel
  • BONES666
    BONES666
    Worth a look.
    http://www.militarybrotherhood.com.au/
  • AJ56
    AJ56
    I went to check it out and got a security warning about it being blocked.. BS
  • BONES666
    BONES666
    Yeah, I just go the same thing. I've contacted their admin to let them know.
  • AJ56
    AJ56
    FYI the Military Brotherhood is a breakaway from the Patriots Australia, A bit of Politics involved but basically the same type of club.
  • OSP1340
    OSP1340
    I can't join. Bummer.
  • Oldman
    Oldman
    Can't get on this site ..............still getting a warning notice posted !!!!!!
  • AJ56
    AJ56
    depending on browser you are using you should be able to turn off the blocking. FF Tools, options, security and under exception un click the box that says" Block reported attack sites". Have a look at the site then reinstate the blocking.
