Online:
John.R, Hilly
FXDWG idle?
FXDWG idle?
AJ56
EFI no choke. I would say it is normal, as long as it doesn't keep that high idle for to long, when you say high idle, ? do you mean a bit higher than normal or does it really idle high. And do you open the throttle a bit when starting it?
There will be others here that may have a better answer than me though....
rider
Sounds familiar, I don't think it is anything to be concerned about.
