Online: WideglidingNZ
Detachable Sissy Bar
  • scurge
    scurge
    Has anyone got any advice on fitting to a 2010 FXDC. Stealers quoted $250.  How involved is it?  Do I have to relocate blinkers?
  • Thomo_Baca
    Thomo_Baca
    Easy job. Blinkers just move a bit further out on the same point, the detatchable mounting points go between the blinkers and the strut. The front mounting points just replace one of the bolts further forward on the strut
    it's not difficult... just follow the instructions.
  • Barney
    Barney
     Hi, done this on my fxd, as others have stated its fairly easy. Just remember to solder and heat shrink  the blinker wires rather than use the shitty crimp on terminals supplied in the kit.
  • scurge
    scurge
    thanks guys for your help did as you said soldered and shrink wrapped the wiring and is all
    good hardest part was carrying it all home in the backpack thanks again cheers scurge
  • Cubicinches
    Cubicinches
    I want one of those super quick bitch bar releases. The ones that let you ditch the wingeing bitch without even changing gear
