Online: John.R, Hilly
Bike stalling
  • Poddy
    Poddy
     Hi Guys,
    my 2006 Deluxe has just started to stall after you have been riding for a couple of hours, example, Sunday rode from did about 150 klms riding and just as I pulled up to the pub it died, no indication  that it was going to happen
    Then when I left and rode another 100 klms I slowed down for a round about and it stalled again
    When you are riding there is nothing out of the ordinary, idle seems find etc
    Anyway got any ideas why this would be happening? To "GO" it must be getting petrol, bike is near stock except for open air-box and pipes; Might check the plugs but it starts fine so am at a loss to what it could be
    Poddy
  • Poddy
    Poddy
    Running nothing at all, when I say the air box is open, I mean just that... the backing plate is open. Rollie (My mach) states that it is the best option when you don't really want or need a stage 1 set up. Very basic increase in air but not enough to need any alterations to the ECM. No piggy back or anything
    How do I check for codes?
    Poddy
  • Poddy
    Poddy
    Nothing at all, but I noticed a small oil leak from below the air filter that's the only thing ( maybe a breather hose is getting blocked or something)
    It starts 1st time every-time, power seems the same
    At a loss
