electral work to my fatboy
  • garyzac
    garyzac
    Hi
    Been thinking of getting C & R Engineering Revesby to find the fault on my Fatboy (no speedo, blinkers wont cancel, wont idle) This only happens sometimes. Harley dealer replaced speed sensor, but still doing it. So im looking for someone whos cheaper & knows what hes doing. So anyone know about C & R reputation?
    Thanks
  • Sparra
    Sparra
    I thought in your other post that you mentioned it's a warranty issue???If this is the case then it shouldn't be costing you anything....
