Online: wildchild, Hilly
2010 Wide Glide Question
  • wa_tony
    wa_tony
    Does the 2010 Dyna Wide Glide have a hydraulic clutch?
  • wa_tony
    wa_tony
    Thanks Crusty.
  • wa_tony
    wa_tony
    I need to remove the clutch lever clamp mounting screws and the screws have an unusual 'star' shaped head (i.e. not allen key). Do I need a Harley tool or do Bunnings sell something that will fit this type of fitting?
    Is it imperial or metric?
  • cm364352
    cm364352
    And try and get a set with a #T27 in it if you plan on doing your own services,you'll nead it for the derby cover.
