Online: softfat
TTS UNABLE TO COMMUNICATE WITH ECM
  • Midnite
    Midnite
    It worked the 1st time I set it up, but now i want to download another map and i keep getting this error "Unable to communicate with ecm", i checked all connections and it wont read my ecm information argh - can any one help pls??
  • BAKES
    BAKES
    Have you turned on the "on switch"
  • Midnite
    Midnite
    Slight lapse of brian cells, i found it - didnt flick the run switch  - dick h88d
  • Midnite
    Midnite
    HI Bakes, yeah what a dick h88d i am - just found it then, thanks mate
  • BAKES
    BAKES
    As long as you sorted it
  • the_mongrel
    the_mongrel
    Yep! I will put my hand up!! I did it too!! :)
