Online: wildchild, Hilly, softfat
Nostalgic air cleaner cover
  • FatboyGooch
    FatboyGooch
    I  have a mikuni carby with K&N  high flow air cleaner with plain chrome cover  on my 2004 fatboy . What i would like to do is replace cover with part no #29138-91  round hd nostalgic bar & amp; sheid logo air cleaner cover . Would any one have one of these covers to give me the measurements  of the depth and the width please ?  Like this look will this work any ideas cheers
    http://www.vpw.com.au/productgroup.asp?bike=1&CatID=850&SubCatID=850&priorCatID=850&PrdGrpID=527
  • FatboyGooch
    FatboyGooch
    Gday  Walka  Thanks for reply  will try and meet you in person this summer . Maybe a poker  run , would like to do the forum bay run around  Sorrento this summer . I have checked out your site the other day you had a round air cleaner with a logo on it much the same as the HD bar & shieid cover part no #29138-91  which i want but dont want to purchase in case it dose not fit. The part no  # MW - 12 - 122  what would the measurements be width & depth  to fit over K & N high flow Air Cleaner . Would you prefer me to ring your site .cheers
    It's 180 mm across , 55 mm thick and is dished in 25 mm in the back. 03 8405 9212. it's made to fit a Bendix but it is very easy to adapt it to a Mikuni
