nightster rear guard on custum
  • c.schembri
    c.schembri
    any one put rear guard from nightster on custom still using custom 2up seat much work involed i kow i need to change tail lights and indercator
    Angle Grinder,,,,,,,,,,,,,,c.schembri Im not being a smart ars ,but most of the Guys on this Site dont do any real Mods to their Bikes so I dont think any one here can help you with questions and you have asked.
    Jump on to XL Forum, the Guys there are crazy about Changing Rear Gaurd, Chosing the right Exhaust and anything that you have asked about over the last few months.
    You will find all your answers there
  • grafpak
    grafpak
    guard will bolt on no need to change indicators unless you want to add nightster lights you do need the matching mounting bracket that sits under the guard and mounts between rear guard and sub frame..i looked at doing this but cut and welded my guard and added a led sidemount..
  • skullster
    skullster
    i cut down a freinds rear guard using my nighster gaurd as a tempelate looked good
