Online: John.R, speedzter
sportster rigid frame
  • dicko1982
    dicko1982
    Hello and great forum fairly new here been looking at posts for a few months but now need some advice.
    Anyone in western australia know anything about swaping sportster frame with a rigid frame ? Not much info out on the net regarding this.
    Seem's easyer to just change it and leave it licensed as stock sporty can't imagtion to many police knowing the difference.
    Any thoughts or comments would be a great help got the bobber erge comming on.
    Cheers dicko
  • dicko1982
    dicko1982
    haha yeah very true go figure...
    any info from people licensing custom build's would be great too
  • kingchops
    kingchops
    Which internet are you searching on?
    There's plenty of info about rigid sportster conversion out there.  There's also lots on this site, see the Sportster section.  You can go replacement frame or weld on hard tail conversion.
    Speak to Walka from VPW, they stock the frames.  The link to their site is in the ads at the top.
  • dicko1982
    dicko1982
    Kingchops have found plenty of info regarding rigid sportster convertion more after licensing infomation.
    cheers for VPW tip been chasing a good online shop
    Hay Dicko ,Give me a call on Monday and I will be happy to fill you in with all the info you need and hook you up with a Motorcycle Engineer in WA 038405 9212
  • rigid
    rigid
    First of all - make sure your new frame makes at least 100 mm ground clearance and it has to be with seat on springs.
    Individually Constructed Vehicle (ICV) - http://www.transport.wa.gov.au/licensing/20501.asp
    National Code of Practice for Light Vehicle Construction and Modification (NCOP)
    http://www.infrastructure.gov.au/roads/vehicle_regulation/bulletin/vsb_ncop.aspx
    Engineering or modification reports and certificates - http://www.transport.wa.gov.au/mediaFiles/LBU_VSS_IB_102.pdf
    Have fun!
