Online: John.R, Stuart
Twincam into shovel frame progress
  • newschool
    newschool
    Posted some progress with my project about fitting 03 Dyna twincam and trans into a 70 shovel frame about a year ago, well just gota paint the tank and it's finished. Gona call it the MONGREL, cause it all made of the following bits: Frame 1970 FLH Shovel, Modified, 2003 Dyna motor trans, and electrical, 2008 Wideglide front end with 2010 fatbob sliders and front fender, VRod rear shocks, 2008 FLH chrome smoothie wheels and tyres, 2005 fatboy forward floorboards and foot controls, 2009 FXDB handlebars and hand controls (used 11/16 front master for dual front disc), 2005 dyna rear brake, with 2005 FLH front brakes, early sporty tank, a combinatination of softail and dyna exhaust, and lots of custom made stuff! its nearly all genuine new and used Harley apart from the aftermarket early FLH rear fender and Lepera seat. Just a word of advice, some genuine HD parts are cheap, for example, 2003 dyna fueltap assy complete was only about AU$35. so if you are building a custom it dosn't hurt to check genuine HD prices first! Have posted some pics.
  • newschool
    newschool
    Had to make a larger diameter lower bearing shell carrier with stop, apart from that all fitted OK.
  • newschool
    newschool
    Also, the engine and trans is all rubber mounted as per 2003 Dyna, runs real smooth! rode it for the first time today.
  • Filthy
    Filthy
     Nice work Newschool - perfect blend of the old and the new.
  • Daggs
    Daggs
    awesome work mate, well done
  • newschool
    newschool
    Like every bike, it is still awork in progress, once registered am going to fit 6" rear flat fender and sissy bar, frisco the tank and fit speedo where the filler cap is now, taller apes, and jus generally tidy the thing up, with louder pipes of course, Lol
  • newschool
    newschool
    Hey, I suppose for the purists, they like usin the foot, but the thunb makes for easier work!
  • Hound_Dog
    Hound_Dog
    Nice work mate
    just looking at the rear shock & swingarm in pic, shock looks a bit too layed down to me, is that swingarm off a dyna?
  • kingchops
    kingchops
    The sporty tank mounted frisco on the backbone is a great look.  Love it.
  • evoshovel
    evoshovel
    Ive got a early evo motor in a 70s flh frame and I was thinking of trying out a sportster tank on my bike.How many ks do you think it would do on a full tank?
  • grim
    grim
    looks great brother --good effort,really nice to see something a bit different--cheers Grim
  • newschool
    newschool
    Swingarm is a highly modified 2003 Dyna unit, used the rear rail sections that had the caliper, axle, and shock mounts etc,
    and rebuilt the whole forward section so it would still mount to the rear of the Dyna tranny, but fit between the original 70 FLH rear frame rails.
  • wilso
    wilso
    great to see guys havin a go in their sheds - the aussie way
  • andij
    andij
    sporty tank looks 94 2 gallons peanut ,youll need a gps with all fuel stations recorded once you get 120 klms youll be needin a fuel fix .good job mate with rubber mountings
    probably would not get the full tank as its tilted back & fuel tap is in center, but looks good my guess would be a 580 pound bike so might get even better economy than a normal dyna
  • roadie
    roadie
    Well done! I love the style. Leave the back guard. I reckon it looks great.
