Online: softfat
Part number needed for master cylinder kit
  • BAKES
    BAKES
    Does anyone know the part number for a Master Cylinder rebuild kit for the front brake of a single disc 2008 custom Sporty, all I know is, it is 11mm in diameter (yep its metric)
    I cant find part number anywhere
    I posted it in the sporty section, but no reply, might have better luck here.
    Bakes
  • BAKES
    BAKES
    Thanks for that ACF 50, but unfortunately that is for 2006 and earlier models.
  • BAKES
    BAKES
    ACF-50
    I don't know how you found it in there, but thanks a million.
