Online: beaglebasher, Merv
WHAT DOES THIS DO ?
  • shovel
    shovel
    There is a plastic tube that fits into inner primary case left hand side of chain tensioner and it goes through a hole to out side primary case, through inspection cover. Can i remove this and block the hole with a plate, Reason why just want to run solid inspection cover.
    IMGP0578.jpg dyna image by shovel1
     Any one know what its purpose is...
  • FatRob
    FatRob
     My guess is that it is the hole for a mid mounted gear shift lever.
    FR
  • Cubicinches
    Cubicinches
    I'm guessing you ordered the bike with forwards fitted and instead of removing the original shift, the lazy dealership left it there. For the home customiser this is OK but for a full price add on at purchase it's just plain lazy and cheap.
  • shovel
    shovel
    Thanks
    930.jpg mids image by shovel1
      Fatrob & Cubicinches both spot on ! Now i can block it of for good...
