Online: Rextheute2022
GOT THE ITCH
  • shovel
    shovel
    Started doing a charging system replace and well got  a little out of hand! So went down and ordered a 49mm front end and brake setup and then thought well i need new bars and controls aswell! Looks like the next months pay is gone. best tell the minester for finances i got them real cheap.
    IMGP0576.jpg dyna project image by shovel1
  • wilso
    wilso
    it happens....lol
  • shovel
    shovel
    Noit good point.....I did use good old vaso on that rectifier plug to push it through the case worked a charm!
  • Fangio
    Fangio
    a shot of penicilin will fix that right up...
