Online: Retroman, obisteve, Soapbox2627, Hilly
BAD start with TTS
  • cm364352
    cm364352
    Hi all,Waz here.I've hooked the tts up for the first time this morning and the problem I have is I can't select a com port.The com port panel drops down ok,I roll the mouse over and they highlite ok but I can't select one.I am using both tts cables.I am thinking I am not getting a connection between ECU and computer,any thoughts??Have I got a dud cable or something else maybe.Any input would be greatly appreciated.Thanks.. ,
  • cm364352
    cm364352
    Thank's for the quick reply Robo61,I'll have a look and see what I need to do.Cheer's mate.
  • cm364352
    cm364352
    I've got a 2010 FXDC Ando,I found the plug ok, it seems I need to install a driver as advised by Robo61.I'll study the manual a bit more and see what happens.Cheer's mate
  • DynaRider
    DynaRider
    Had the same issue. Just used the driver on the disk, and all was good for windows 7.
