Online: softfat
Opinions Please???
  • the_mongrel
    the_mongrel
     So I have just come back from my first run with the new pipes on!  So now I am running the Kurry Corsair and the VnH Radius 2 in 2.  I have put the map AE176-002 and it feels like it is running great.  No popping on decel or anything like that - HOWEVER - the file list from TTS states  "Engine 1580 AC Only"
    So I have looked though the maps and found this one...  PZ176-002   Which states "Engine 1580 AC and Exhaust"  So should I remap? and does anyone know what the difference is??
    Mongrel
  • the_mongrel
    the_mongrel
    Thanks Ando - I figured that, but I just wanted to put the feelers out there in case someone wants to give me a good reason why not to use the AE map.
    The bike ran really well mate - no popping or anything. Pulls really well. I guess at worst I am probably running a little rich - which is better than lean I guess.
  • ==ShaDoW==
    ==ShaDoW==
    Ae 176 is the one i used sideshots and AC
  • the_mongrel
    the_mongrel
    Thanks Shadow. I just got back from a really good ride. About 200 clicks, and no popping, pulls good!! It sounds like a beast too. Probably running a little rich as there is a mild black sooty residue in the inside of the pipes. Not bad, but its there.
  • the_mongrel
    the_mongrel
    Hi Lads
    I was going to ask the same question!! I have loaded the AE176 map with Kurry Corsair and VnH Radius 2in2 and the bike goes like a bought one! :) I think it is running a little rich though.
    I did disable the active air and exhaust. I have put about 300kms on it since I loaded the map and have had no problems. Pulls hard, especially on 5th around 110.
    I will do some V-Tunes eventually, but need some time and good weather for that. :)
  • the_mongrel
    the_mongrel
    I'm like you Robo. The difference between what the bike is now, and what it was, is chalk and cheese.
    If no popping and the bike is running fine, I think at worst you will be running a little rich. If you were lean, you would be popping like mad. I think a little rich is better than a little lean, but someone else with more knowledge might chime in.
  • the_mongrel
    the_mongrel
     Cool shit man...  When you have finished, can you teach me??
  • Gnoo
    Gnoo
    far king what %#&* ??
    guess reaming out the main jet just don't cut it no more !!
