Big Radius on Fatboy
  • the_mongrel
    the_mongrel
     Hello Lads,
    Just about ready to go and tackle the install of my Radius, and have a couple of questions...
    If you have the Radius Pipes with floorboards, does the board hit the pipe when you flip the board??
    What do I do with the Active Exhaust valve?  Just unplug it and tape it up?  I have disabled in the map already.
    Does anyone have access to the Manual to give me the torque specs... Or can advise on how tight I should do the header nuts?
    Mongrel
  • the_mongrel
    the_mongrel
    Thanks Dave,
    I have the WilliG Board Inserts and mine hits when I flip the board up. I have tried everything to try and move it further in, but it appears to be sitting right where it should! I can take a pic if you like.
  • the_mongrel
    the_mongrel
    Hmmm... So does yours hit or not? I am just trying to figure out wether I have screwed up or not dude.
  • the_mongrel
    the_mongrel
    Yep - They are clear. I reckon my boot is going to get close to the heat shield (if not hit it) but I suppose I can live with that!
    -M
