Online: WideglidingNZ
Ironhead parts availability
  • chrise1961
    chrise1961
     Any advice on where to shop for Ironhead parts, expect over time I will need lots of various bits and pieces, but for the moment a Top End gasket kit and valve stem seals would be a start. Happy to shop online with any reliable retailers. Cheers, Chris.
    what model sporty / can help with gaskets or just ring redgraves m/cycles sydney , iron head 's don't have valve guide seals
  • chrise1961
    chrise1961
     Ok thanks, mechanic told me that front cylinder needed valve stem seals and/or valve guides...guess that answers the question of which. Can valve stem seals be retro fitted? Sporty is a 1979 XLH, or was originally..frame and engine numbers still match though. I have a leaky rocker cover gasket on the front cylinder so apparently the head must come off to repair it, I need Top End gasket kit and pushrod seals if they are not included....may need some valve guides too.
  • chrise1961
    chrise1961
     Cheers, have dealt with Alex in the past with good results, was hoping for an alternative closer to home .
    hi you can pull the front rocker box off with out pulling  it's head-off, don't worry about valve guide seals , if its worn-out , do a  top end rebuild barrels & heads  , that way you know were you are
  • chrise1961
    chrise1961
     thanks daddyracer, have done the job and did not have to take the head off....all good now..just need some more horsepower......
