Pipes are hear - Do I need a new map?
  • the_mongrel
    the_mongrel
     Hi Lads,
    Last week I installed my Kurry Corsair heavy breather on my 2010 Fatboy and mapped it with AE-176
    The bike is running the stock headers, with OuterCycle Slash Cut Mufflers.
    The question I have now is.... when I put the VnH Big Radius 2 into 2 on the bike tomorrow, do I need to remap, or do I use the same map?
    AND LASTLY
    Do I leave the baffles in the Big Radius, or take them out?
    Mongrel
  • the_mongrel
    the_mongrel
    Thanks mate,
    I suppose I would try it and see.
    So you think that are WAY too loud without baffles? I suppose I can always try it and see. :)
    Would popping not mean a lean mix?
