Online: Stuart
Big Radius and Dipstick
  • Mainey88
    Mainey88
    Deciding on whether to throw some V&H big radius on the 06 Dyna but looks like the pipes cover the oil dipstick, all I really need to know is do they ? or should I leave the big radius alone and settle on different pipes.
    If they do how do you check the oil ?
    Mainey88
  • Purnong
    Purnong
    You can still get the dipstick out no worries,
    Mate has the big radius 2-1 on his Dyna, Just have to be a bit careful when the pipes are hot
  • Purnong
    Purnong
    Not sure on the 2-2 Mainey
    I had a quick look on the Yank forum and one poster said he had to loosen the rear heatshield to get to the dipstick and another said he had no problem and something wasn't fitted properly on the first guy's bike
    Couple of links for ya
    www.hdforums.com/m_2559503/tm.htm
     www.hdforums.com/m_2601945/tm.htm
    Sorry mate, Can't be much more help
  • Mainey88
    Mainey88
    Thanks for the links purnong, looks like its BR for me
  • andij
    andij
    mainey heaps of good systems out ther ,the slip ons are good solution S@s one of the best ,rinehart have the best 2.2.system.but loud ,vh long shots or straight shots perform well ,d@d ,supertrapp are good performers 2.1 .i ask dyno shops for best power choices,otherwise its the looks.
  • Mainey88
    Mainey88
    Just wanting a great note and good looks at this stage andij, when the power bug hits this will all change, will check out those other places though, ta.
