TTS HELP - ECM not found.
  • the_mongrel
    the_mongrel
     Hello Lads,
    So I am trying to save my factory calibrations before i retune.  I have everything installed, but when I go to save the factory settings it fails.
    I click Get ECM Info and all four fields come back with NOT FOUND.
    Now I know it is communicating with the bike because if I turn the bike off I get a different error stating that was no response from the ALDL adapter.
    Any clues??
  • Yositime
    Yositime
    Are you using the TTS supplied USB-Serial adaptor or something else?
  • the_mongrel
    the_mongrel
    Hi - Problem sorted. I didn't have the run switch on! OOPS!!
  • Yositime
    Yositime
    You know I was going to suggest that, but I didn't want to seem like a wise a$$....
  • the_mongrel
    the_mongrel
    heheheh All good!!
