just bought tts, but no mechanic has heard of it <img src="/DesktopModules/NTForums/themes/_defau
  • the_mongrel
    the_mongrel
    At least my dealer knows and uses the TTS, but I am going to have a crack.
    I have the Kurry Corsair waiting to go on this weekend! :))
  • nimo07sporty
    nimo07sporty
    yeah i just bought a workshop manual for my bike today and mentioned that il be buying a tts soon to the dealer and he asked what is that so had to explain to him its a tuner duh lol
  • Steve Cole
    Steve Cole
    If you look in the tuning guide we show you both the 25 deg and 8 degree injector. You can then look and determine what you have on your bike. Appendix D, Page 47
  • Bobtail
    Bobtail
    Here's my take on your TTS question......
    I'm an avid user but only understand the basics....If  aftermarket changes are made to your bike you will need to adjust the air fuel ratio....Too lean a burn will do harm to your bikes engine....With a TTS starter map, that is taken care of, you then do a few Vtune runs to blend and fine tune... You will notice straight away that the bike runs good or bad, a few tunes will generally sort it out...Take note of fuel consumption, engine temp, sooty exhaust, black spark plugs etc..As long as your bike gets enough fuel to not run lean your pretty safe....After all that and you get realy enthusiastic you can start playing around with spark advance etc....I leave that to the experts..
    The good thing about TTS is that the factory ECM is still in play....Knock retard, engine temp and other settings are still active...
    I printed of the TTS manual and read it a few times, it's very instructive and if you follow it closely you can't go wrong, The mates I have made on this forum have helped heaps also.
    There are a lot of guys on here that will steer you in the right direction.....
    Bt
