Quick TTS questions
  • the_mongrel
    the_mongrel
    Hi Lads,
    Just a quick one...
    A nice large box turned up today with some goodies... notably my Kurry corsair kit and TTS.  My Big Radius are not due for a couple more weeks yet, but I would love to get this Airkit on.
    Can I stick the air kit on and load a map that will suit the Corsair with Outer Cycle Slash Cuts???
    Mongrel
  • the_mongrel
    the_mongrel
     Thanks Ando,
    Is there a map readily available for it?  Or will there be one with the TTS?
    Do they supply some maps with it?
  • the_mongrel
    the_mongrel
    Thanks mate for all your help, and I am sorry if these questions have been asked a thousand times!!
    Man - I tell ya - The Corsair is bigger than I was expecting!!!
    There is a nylon type sock over the filter itself, is it really needed - it makes it look crap I reckon! And how do air kits like this go in the wet?
    Mongrel
  • the_mongrel
    the_mongrel
    Thanks. It is this see-through almost like fly screen. Its coming off I reckon!! :)
  • the_mongrel
    the_mongrel
    Hmm we'll see!! Once it goes on... if it looks shit... like Fatty would say... its GOoooOOOnnneEe!
  • the_mongrel
    the_mongrel
    Ando - I have managed to save my stock config and am about to load QD-176. However you previously mentioned about switching of the AC and AE and then loading AE-176 MAP
    I can't seem to find that option in the software - also keep in mind I still have my outer cycle slash cuts on with the Kurry Corsair.
    Can I ask why I load the second map over the top of the first one?
    John
  • the_mongrel
    the_mongrel
    Ok - so should I disable the exhaust while I run the stock headers and outer cycle slash cuts? Do I want to disable them, and why dude??
  • the_mongrel
    the_mongrel
     Ando Ok - here is an update
    I have loaded the maps as discussed, but I am not sure things are as they should be.
    The idle at startup is off the chart!!  It is not just idling high - its off the chart!!   So much so that it scared me and made me turn the bike off.   Now I am not exaggerating - its WAY too high.
    So here is the setup....
    Kurry Corsair Airkit with Solenoid disconnected.
    Stock headers with Outer Cycle Slash Cuts
    Loaded  Map QD 176 and disabled Air Intake and Enabled Active Exhaust.
    Loaded AE 176
    Something is obviously not right.
    Any ideas??  Are these the right maps for my 2010 Fatboy?
  • the_mongrel
    the_mongrel
    Hmm... I wonder if I have loaded the right map....AE 176 does not mention anything about an air kit in the description.
    ANDO - Do you think this is the right map?
  • the_mongrel
    the_mongrel
    yep I did check that. I can hear that SNAP sound when I let go of the throttle - so I don't think that is it - but I will have another look.
  • the_mongrel
    the_mongrel
    PROBLEM SOLVED!!!
    MY BAD - FUCKIT!!!
    When you install the Kurry Corsair there is a "Mini Airkit" that you need to connect to a couple of Banjo breathers on the cylinders. Then you have to stuff that little air cleaner up and under the tank. Now there is not much room under there and when I pushed it in it popped off a connector that connects directly to the back of the air intake. GRRR!!!!!
    So after pulling the Kurry kit off again I found it, fixed it, reloaded the maps and BINGO - idle good now!!
    Ok - NOW....
    I just found PZ176 002 B1
    It states its for 1580 A/C and Breather Kit and Performance touring Mufflers.
    What do you guys think??
  • the_mongrel
    the_mongrel
    Yeah - I will see how it runs today - I will take it for a spin. If it seems to be going OK I will Vtune and go from there.
    I have to do it all again when the Big Radius pipes turn up.
