brake lights always on
  • dattabo
    dattabo
    hey guys wondering if anyone can shed some light my brakes lights are always on and when i turn the ignition off only the front indicators flash when the alarm sets itself, normally both front and back flash when it arms itself????
    No mention of your bike type, but I'm thinking there's a switch that tells the brake lights when to light up - yours is prolly cactus. Grab a manual, find it, replace it. I presume you've tried messing with the pedal (lifting it up/down a few times. Have you done anything to the bike lately, like changed a wheel, the grips or whatnot?
  • dattabo
    dattabo
    Hey bro, yeh sorry its a 2008 1200n sportster, yeh lifted the pedal and pulled apart the brake leaver and the button was pushing back in so im a little lost especially with the indicators not flashing on arming, changed the bars about 3 weeks ago but it has been working up until the weekend
  • Burnzi
    Burnzi
    Mine was stayin on after I fitted apes found out it was the small lever that activates the switch in the switch blocks. I just pulled the switch block away from the master cylinder and bent the little lever a bit with a blade screwdriver.
    Before that they wern't workin at all found the tyre had rubbed through the wire, always pays to check the simple stuff first hey?
