• wilso
    wilso
    i wanna paint my tins to finish my girl off , but im looking at maybe getting some other tins and tanks and keep the originals spare - ive got a 99 wideglide so will any softail tank fit? 1 piece or 2 ?
    thanks in advance fellas
  • wilso
    wilso
    surely someone knows out there??/????
  • Nightrider
    Nightrider
    I got new tins primed from the factory.
    Was pretty cheap used M and M cycles in the states.
    I have an Iron so not sure about a softy.
    Plenty of after market stuff out there but i have heard that after market tanks can be unreliable as far as the inside sealing goes.
    Im no expert though
    Walka may know he is the master builder.
    NR
  • Nightrider
    Nightrider
    I just got a new Sporty tank on ebay there is heaps around
    dunno if they'll fit your bike but lots on Ebay ive been looking out for mine a while but finally found one in australia.
    be patient one will turn up.
    NR
  • rockyrob
    rockyrob
    I   was looking at painting my Fatboy a while back  and ended up buying new tins  painted to my colour from colormania in the usa delivered here  for around 1400, ( cheaper than some of the quotes i had locally for paint alone. Now have two sets to swap when i get bored. Tins arrived last week but are stuck in depot at Rocky airport which is closed due to floods so cant pick them up for a week or two:(
  • wilso
    wilso
    thanks everyone.
