You've gotta wonder why....
  • the_mongrel
    the_mongrel
    Why in gods name did Harley ever put the indicators on the bars??
    I relocated mine tonight on my Fatty, to the forks. Took me 20 minutes - but I gotta wonder why they don't put there from stock.
    Seems like just about everybody relocates them anyway!!
  • 99Fat
    99Fat
    Any chance of a photo?
  • the_mongrel
    the_mongrel
    Sure - I will get a pic tonight for you.
    It was really easy actually.
    I grabbed a couple of bolts that bolted straight into the fork nacelle, and cut the head off. Fortunately this is the same size and thread for the indicators. I screwed that in which left a bit sticking out. I then used two nuts. Once to secure the bolt shaft to the fork, and the other to use a s locknut for the turn signal.
    The cables are VERY easy to identify coming out of the bars. Just snip, resolder and heat shrink! The only pain was opening the control switch housings. Other than that - very easy!
    I will post a piccy later tonight for you.
    Mongrel
  • the_mongrel
    the_mongrel
    hmmm... Take the red ones brother and repeat... "In with the good air, and out with the bad" ;) ;) ;)
  • the_mongrel
    the_mongrel
     OK - Some pics.
    Was a bit hard in the light I had - but you will get the idea..
    That Allowed me to install my new mirrors!!  :)
  • the_mongrel
    the_mongrel
     Thanks mate - I am getting there slowly.
    Although the Minister for Finance and Pleasure does not know why is it that I bought a brand new bike, yet I still need to buy a bunch of new bits!!  :)
    Women - I don't try to understand them!!
  • the_mongrel
    the_mongrel
    Thanks mate!!
    I just finished whacking a bunch of stuff on the girl including a new Air kit. If you are interested you can check it out here... http://www.photobucket.com/themongrel
    Mongrel
  • the_mongrel
    the_mongrel
    Hmmm What happened Toshigav?? Where did your post go dude?
  • the_mongrel
    the_mongrel
    All good oz!! :)
    I am planning in putting a light bar on the front eventually - when the Minister for Finance and Pleasure gives me my next allowance!! ;)
    But I could not handle them on the bars, so they had to go somewhere. Until I get the light bar I am putting the visors on today - so that will tidy them up a little.
    Mongrel
