Online: TNT
THUNDERMAX INSTALL
  • Peter
    Peter
    Ok i give up, and I am going to get a Thundermax system. My problem is that I am terrible with computers so I need all the help i can get with the install,should i buy the closed or open loop? what are the benefits of each etc. It is going into an 06 softail and i am going to have a crack at it myself. Any simple to understand instructions would be really appreciated (especially if you have pics) and any problems that I might run into. So far my bike has S.E. muffs and high flow filter with race download. Thanks in advance. Also how much should I pay and where did you guys buy?
  • sophtayl
    sophtayl
    Hi Peter,
    In simpe terms, what are you planning on doing in the future and trying to achieve with whatever system you select. Thundermax is a great unit, especially if you plan to do a lot of mods in the future.
    In regard to the FuelShot, yes it is readily transferable from bike to bike as long as it suits the Engine type. eg- the 06 being an 88 cu is not the same unit that would be used on a '07 96 cu. Extremely simple to use, and will handle most peoples mods out of the box. If parameters are maxed out, then we can reprogram to suit. There is no computer interface required and adjustments can be made whenever you want.
    Happy to anser any questions you may have.
    Kind regards
    Mick
  • BACAMICK
    BACAMICK
    go the TMAX , ull never need any thing elese what ever u do to ur donk it will support it , from mild to wild to nitus to supercharging , i use one and am verry happy, im verry happy with the quick adapting it done going from adelaide sea leval, to the freezzzzzzzzing cold inland, about 80 ks and it was good again, ie no poping n shit,
    IF I CAN PLAY WITH A T/MAX ANY! CAN
    if ur not going to travel aust with diff riding areas or work ur donk one day ya may aswell stay with wat u got  or a cheaper setup like described above
  • PigironBob
    PigironBob
    Seems pretty cut and dried to me.
  • GREG
    GREG
    I'm a big fan of the t/max. Have the auto tune on my 07 softail.
    I'm with scotty on this one, if you are going for no auto tune you may as well save the extra bucks and stay with what you have got.
    If ya can use a forum on the computer than you can set up the T/max. It aint hard.
    The install is reasonably straight forward. There is enough of us who put them on to answer ant specific questions.
    M&M cycles give very prompt service. 6 days from them to me.
    the o2 sensors are there for the long haul and they dont fail readily. They are funnily enough designed to work in the exhaust environment. If by chance they do the t/max will just run on open loop anyway, so the bike will still get you where you want to go.
  • Peter
    Peter
    Wow,ya ask a simple question then come home from work to this,thanks guys. When I first read about the thundermax it was without autotune and everyone was raving about it and sayin how much of an improvement it would be over a download ?? I understand the benefits of autotune but I also understand that a bike can run efficiently with a carby ( not perfectly ) so to my way of thinking if I go the NON autotune I should be able to get it set up pretty well. I can live with not perfect. But what  Scotty said about not being able to find a map for it is a problem ? By the way Scotty I am not asking for someone to tell me what to buy and I only asked if it was a simple case of plugging in and riding away, you don't have to answer my questions I am just trying to understand a bit about the system so that I can make an informed decision,this sort of stuff obviously comes easier to you than me because half of the info you wrote I still dont understand,but I'm trying.
  • Peter
    Peter
    Yeah thanks Scotty,I do understand that the autotune would be a better option,my point with the carby was that once it is tuned you are trusting it to do its job just like the NON tune thundermax (assuming it has been set up correctly). Things used to be so easy,now I have 4 remote controls when all I used to do is get up and change the channel,thats progress 4 ya.
  • Peter
    Peter
    Yeah I could tune the katana in about the time I could fuel it up LOL.
  • BACAMICK
    BACAMICK
    i agree ur wasting $$ if ur not going auto tune , if u ride the same level all the time its probly ok , if ur into hills sea and a mix of diff states etc u cant go past the auto, i went to coffs last yr and no some bike could feel the diff in altitude , me i felt nothing differant  i went the auto cause my bike is of tap thats the only reason , i wanted the bestwhat are u after ? more mods or just a little better performance ? ur wasting $$ if u are happy with a bit better , go with WANKER , he nos his puters/bikes inside out
  • Peter
    Peter
    Thanks Graham,I would like to ask you a couple more questions. Can I email you or you can have my phone number or I could call you either way I'm happy. Thanks again.
  • dynamagic
    dynamagic
    HEY GUYS , I'M GOING TO GET A AUTO TUNE TUNDER MAX FOR MY DYNA , CURRENTLY RUN A POWER COMMANDER , BUT UNFORTUNATLY THERE AS GOOD AS THE TUNER DYNOING THEM , I'M SICK OF PAYING GOOD MONEY FOR DISSAPOINTMENT , DYNO TUNING BEING THE RATHER LARGE PRICE THAT IT IS , I'M OVER IT , I FIGURE THAT THE EXTRA MONEY SPENT ON AN AUTO TUNE SETUP FAR OUT WAYS THE COST AND TIME RUNNING AROUND , I JUST WANT TO NO WHEN I RIDE MY BIKE IT GOES WELL , WE SPEND BIG MONEY ON ENGINE MODS , SO WHY NOT FINISH THE JOB PROPERLY , REALLY ITS A NO BRAINER , LIFES SHORT SPEND THE EXTRA CASH , GET THE RESULTS , BE HAPPY , MICK
  • GREG
    GREG
  • Peter
    Peter
    If it wasn't for those breasts I would worry about you Greg
  • GREG
    GREG
    So which way ya going Pete? Auto tune / no auto tune / something different?
    I worry about breasts myself sometimes
  • Peter
    Peter
    Going with the NO AUTO TUNE it has already been mapped at Morgan&Wackers and I will be picking it up tomorrow morning and fitting it myself.
  • GREG
    GREG
    let us know how the install goes pete, Hope it does what you want, with minimal grief.
    gmeikle, the $750 gives you flexability.
  • Tracychop
    Tracychop
    Still think you should look into the Big Joe Choppers Fuel Shot Gen 111. You want performance....The proof is in the pudding.
