Online: Stuart
Stage 2 upgrade
  • andij
    andij
    hey hogbag are u going cam gears or staying with chain ,
  • andij
    andij
    thanks karl they need to be wiyh the lift u get .
  • Purnong
    Purnong
    Have you had or seen much feedback from people using these cams in a stock motor Scotty?
    I would like to fit them to my 08 Dyna if they are a true bolt in, I dont really want to do any other work to the motor
  • andij
    andij
    hey scotty do the 54s need head work and increase in c,r, .iam surprised u dont need hi lift springs as suggested by andrews ,the seem to suggest that 510 lift is bolt in the rest need better flowing heads and more compression ,
  • Purnong
    Purnong
    Shit, That was quick mate
    I have a mate who is a qualified motorbike mechanic and he has told me that I need to get more K's up on the bike before changing cams, to give everything time to settle in
    Bike currently has 1300k's, Whats your thoughts on that?
  • Purnong
    Purnong
    Thanks Scotty
    I was worried about the warranty as well but stuff it
    I have changed pipes, Fitted PCIII and stage 1 Air cleaner now so I reckon anything engine related would probably stuff the warranty anyway unless I put it all back to stock before taking it in
    That would be a pain in the arse to do now anyway so I will probably do the cams soon
  • Purnong
    Purnong
    Thanks Karl
    First service coming up soon, So I better get ordering
    I see the part numbers above for the cams and the adj pushrods, What else do I need?
    Scotty do you have the part No's for the gaskets and O'rings?
    Amazing that it is cheaper for cams than a bloody sissy bar
    Thanks again
  • Purnong
    Purnong
    Thanks again Scotty
    Bloody good info mate, Just ran the numbers through M&M's
    Cams 54H 06 Dyna, 07-08 TC 0925-0278   $223.16
    Pushrods 18404-08  $140.25
    O-Ring 11293 x1  $0.99
    O-Ring 11301 x2  $1.98
    Seal Exhaust 65324-83A x2  $9.98
    Gasket CA 25244-99A   $4.50
    Grand total of  $380.86
    The cam spacers, Would it be better to pull it apart then run into Peter Stevens if I need one or just order a set anyway?
  • andij
    andij
    so scotty wat rig do you ride, karl recomended the 54s to me ,and ive seen how stixs go with the 55s ive been looking for bolt in set up for 95 hp , idont need100 hp and like cam gears set up its been hard to make a choice .
