Online: devkkumar59
forbidden 4 into 1 pipes ??
  • HAMM3Rsix
    HAMM3Rsix
    Hi all i am looking at puting some forbidden 4 into 1 pipes on my 2010 fatboy lo can this be done .? dark side slash $699 from vpw.
    whats the go with the o2 sensor?
    Plus fitting
    a TTS
    With a Karyun Pro R air filter? black of course lol
    any feed back would be good
    thanks in advance.
  • Dragon
    Dragon
    Dont know what motor you got, but I only got 2 cylinders when I bought both my harleys mate. I think thats why 4 into 1 pipes are forbidden
  • BAKES
    BAKES
  • Tassiedave
    Tassiedave
    Fourbidden 4 Into 1 Pipes
    Never before has anything like this been done and definitely never mass produced Hooker FourBidden series V–Twin Headers. Four 1–3/8” primary tubes merge into one 3” collector for awesome styling and aggressive sound removable baffle included). Attached to the collector is a 3” two way adjustable tip engraved with the famous Hooker logo.
    Part No. Description Price Buy
    HOO-27908-3DHKR 4 to 1, DARKSIDE, SLASH $699.00
    HOO-27908-3HKR 4 to 1, CHROME, SLASH $699.00
    HOO-27908-5HKR 4 to 1, CHROME, TURN $699.00
  • HAMM3Rsix
    HAMM3Rsix
    ok so we know what they are any feed back to the origanal question???
    That part number is from vpw i beleive $699 plus $43 dollars to your door.
    Yes I do Know and No you dont need 4 O2 Ports.
    You can weld in Oxy Sensor Port . I sell them $12.00 each , you just need to get them Miged on to the Pipes . If you use a PC 5 you dont need the Oxy Sensors
  • HAMM3Rsix
    HAMM3Rsix
    Thanks walka whats a PC 5 and can you give me a bit more info on
    Can i save orginal setting and what options you can change with the PC5 ??
  • HAMM3Rsix
    HAMM3Rsix
    Soz
    And how come you dont need it i thought for a EFI system you had to sample the exshuast to get mixtures
