Online: imoo6170
Fatbob Rear Brake (lack of!)
  • BURTO
    BURTO
     OK, we all know the rear brakes on late model HDs are crap!
    Was hoping someone could suggest a better calliper (preferably 4 spot) that will fit the Fatbobs rear.
    Doesn't look like a lot of room between rotor and mag wheel!
    Has anybody solved this problem......the front brakes are brilliant, the rear are wooden and almost non existent compared!
  • BURTO
    BURTO
     Finally installed new floating rotor and Lyndall GOLD pads to rear of Fatbob. (decided to wait till I had wheel off for new tyre)
    Theres definitely a big improvement, 30% easy...........still not great, but heaps more feel than before! Reckon I can live with em like this.
    Will definitely replace fronts with Lyndall pads when I wear the originals out.
    Thanks Styx for the info!
    Burto.
