Online: devkkumar59
Map for Fatty, Radius, and Kurry Corsair
  • the_mongrel
    the_mongrel
    Hello Lads.
    So my parts are on the way...
    TTS, VnH Radius 2 into 2 and a Kurryakyn Corsair kit.
    Is there a Map already available that I can use to start with?
    Oh yeah... its a stock 2010 Fatty!
    Mongrel
  • the_mongrel
    the_mongrel
    Thanks Ando,
    I believe the Radius come with O2 sensor ports - that thread mentions something about switching them off, can you shed some light?
    Mongrel
  • the_mongrel
    the_mongrel
    Right!!! OK... When the time comes - I may need some help. :)
  • the_mongrel
    the_mongrel
    Thanks Oz.
    I am getting a little confused as to closing off the AC etc or not to close them off?
    I need to keep reading I think!! :)
  • the_mongrel
    the_mongrel
    Thanks Ando. Doesn't the Big Radius have the sensor ports??
  • the_mongrel
    the_mongrel
    Thanks mate - not quite following - Closed loop?? - But I guess I will when I get the pipes. :)
    Mongrel
  • the_mongrel
    the_mongrel
    Yep - I think you are right.
    Once I get them, I know doubt will be back to ask questions!! :)
  • the_mongrel
    the_mongrel
    That's what I thought.
    Lots of popping on decel - not bad - but I can hear it - so it is certainly running a little ugly.
    Cant wait to get the pipes and breather on it.
